[gdal-dev] Re: HDF-EOS vs. GDAL: order of dimensions
Ivan Shmakov
oneingray at gmail.com
Fri Jan 25 00:31:38 EST 2008
>>>>> Lucena, Ivan <ivan.lucena at pmldnet.com> writes:
>> I believe that the driver should be given options already read and
>> parsed, and not the helper file name or its contents. This way,
>> both the options parsing and the whole options concept could be
>> much generalized among the drivers. And it requires introducing
>> an ``options'' structure, which may be initialized either by GDAL
>> reading the helper file, or by the calling application itself.
> I am dealing with a real scenario where because of the complexity,
> variability and quantity of HDF files I can't see how the open
> option would play a role. For me that should be a separated thread,
> IMHO.
> But that is how I would like to see it working:
> There are 350 HDF that I want to server it a webapp. First thing to
> do is to create a catalog. I am not a big Mapserver expert but I
> guess that you should use *gdaltindex* for that. That will happen
> in the server machine just once, during some sort of data
> preparation process, and once in a while when you update it with
> new files.
> Running gdaltindex, the HDF4 driver will look for hdf-helper file
> on the same folder as the driver and then on <gdal>\data. If there
> is a match between a pair {product name,dataset name} on the data
> file and one similar pair on the helper file, the driver will use
> the dimension order from the helper file, ex.:
> SUBDATASET_52_NAME=HDF4_EOS:EOS_SWATH:"MYD06_L2.A2006220.hdf":mod06:Cloud_Mask_1km
> SUBDATASET_52_DESC=[2040x1354x2] Cloud_Mask_1km mod06 (8-bit integer)
> --> This dataset has 2 bands of 2040x1354.
> SUBDATASET_28_NAME=HDF4_EOS:EOS_SWATH:"MYD06_L2.A2006220.hdf":mod06:Radiance_Variance
> SUBDATASET_28_DESC=[7x408x270] Radiance_Variance mod06 (16-bit integer)
> --> This dataset has 7 bands of 408x270
> That is because this file is a very known problematic product that
> doesn't have dimension order information for some datasets:
> Product: "MODIS Level 2 Cloud Properties"
> Dataset: "Cloud_Mask_1km"
> Dataset: "Radiance_Variance"
> Does it make sense?
Could you please test your data with the proof of concept
patch I've posted to the list recently? I've put the
following into my "$GDAL_OPTIONS_FILE" and it seems to make
GDAL work correctly with the dataset:
$ cat "$GDAL_OPTIONS_FILE"
{ expr 0 } { some lines skipped }
{ match "^HDF4_EOS:EOS_SWATH:.*:mod06:Cloud_Mask_1km\$" } {
options hdf4 { dims { iy 0 ix 1 iband 2 } }
$ gdalinfo 'HDF4_EOS:EOS_SWATH:"MOD06_L2.A2002234.0515.003.2002243234435.hdf":mod06:Radiance_Variance:OPTIONS:source
gdal-options.tcl'
Driver: HDF4Image/HDF4 Dataset
Files: MOD06_L2.A2002234.0515.003.2002243234435.hdf
Size is 1354, 2040
Coordinate System is `'
GCP Projection = (null)
GCP[ 0]: Id=, Info=
(2.5,2.5) -> (72.4288864135742,45.6274261474609,0)
GCP[143]: Id=, Info=
(1322.5,2037.5) -> (91.8692855834961,24.5590171813965,0)
Metadata:
HDFEOSVersion=HDFEOS_V2.4
Number_of_Instrument_Scans=2040
Maximum_Number_of_1km_Frames=1354
Parameter_Type=MODIS Input
Cell_Along_Swath_Sampling=1, 2030, 1
Cell_Across_Swath_Sampling=1, 1354, 1
Geolocation_Pointer=External MODIS geolocation product
description=See MODIS atmosphere QA plan for details
Geolocation:
X_DATASET=HDF4_EOS:EOS_SWATH_GEOL:"MOD06_L2.A2002234.0515.003.2002243234435.hdf":mod06:Longitude
X_BAND=1
Y_DATASET=HDF4_EOS:EOS_SWATH_GEOL:"MOD06_L2.A2002234.0515.003.2002243234435.hdf":mod06:Latitude
Y_BAND=1
PIXEL_OFFSET=2
PIXEL_STEP=5
LINE_OFFSET=2
LINE_STEP=5
Corner Coordinates:
Upper Left ( 0.0, 0.0)
Lower Left ( 0.0, 2040.0)
Upper Right ( 1354.0, 0.0)
Lower Right ( 1354.0, 2040.0)
Center ( 677.0, 1020.0)
Band 1 Block=1354x1 Type=Byte, ColorInterp=Gray
NoData Value=0
Band 2 Block=1354x1 Type=Byte, ColorInterp=Gray
NoData Value=0
While without the helper file GDAL seems to misinterpret the
dimensions:
$ gdalinfo 'HDF4_EOS:EOS_SWATH:"MOD06_L2.A2002234.0515.003.2002243234435.hdf":mod06:Cloud_Mask_1km'
Size is 2, 1354
Metadata:
Corner Coordinates:
Lower Left ( 0.0, 1354.0)
Upper Right ( 2.0, 0.0)
Lower Right ( 2.0, 1354.0)
Center ( 1.0, 677.0)
Band 1 Block=2x1 Type=Byte, ColorInterp=Gray
NoData Value=0
Band 2 Block=2x1 Type=Byte, ColorInterp=Gray
NoData Value=0
Band 2039 Block=2x1 Type=Byte, ColorInterp=Gray
NoData Value=0
Band 2040 Block=2x1 Type=Byte, ColorInterp=Gray
NoData Value=0
