[gdal-dev] TRMM in GDAL?
Yann Chemin
yann.chemin at gmail.com
Fri Jan 25 01:32:25 EST 2008
On 25/01/2008, Frank Warmerdam <warmerdam at pobox.com> wrote:
> Yann Chemin wrote:
> > Hello I am trying to convert TRMM 2B31 from HDF into anything more
> > common for processing (Gtiff, HFA, ...)
> > Basically gdalinfo returns this:
> > yann at gis4400:~/TRMM$ gdalinfo 2B31.070101.52014.6.HDF
> > Driver: HDF4/Hierarchical Data Format Release 4
> > Size is 512, 512
> > Coordinate System is `'
> > Corner Coordinates:
> > Upper Left ( 0.0, 0.0)
> > Lower Left ( 0.0, 512.0)
> > Upper Right ( 512.0, 0.0)
> > Lower Right ( 512.0, 512.0)
> > Center ( 256.0, 256.0)
> Yann,
> The above sounds like the bogus parent dataset. Were there
> subdatasets? If so, do a gdalinfo on them and see if they have
> meaningful georeferencing.
This is all that gdalinfo returns. However, the c code provided by
TRMM website reads several subdatasets...
yann at gis4400:~/TRMM$ ./select_vNsds_linux 2B31.070101.52014.6.HDF
Number of SDS arrays in file: 9
1) geolocation dimensions = 9246 49 2
2) dHat dimensions = 9246 49
3) sigmaDHat dimensions = 9246 49
4) rHat dimensions = 9246 49 80
5) sigmaRHat dimensions = 9246 49 80
6) rrSurf dimensions = 9246 49
7) sigmaRRsurf dimensions = 9246 49
8) latentHeatHH dimensions = 9246 49 13
9) spare dimensions = 9246 49 4
> If there are subdatsets but they lack georeferencing, you may
> find you can use "-a_ullr -180 40 180 40" on a gdal_translate line
> to assign the following bounds as part of a translation.
Thank you for this I will try this in any case.
Yann
> Best regards,
> > while in the 2B31.070101.52014.6.HDF.XML:
> > <SpatialDomainContainer>
> > <HorizontalSpatialDomainContainer>
> > <BoundingRectangle>
> > <WestBoundingCoordinate>-180</WestBoundingCoordinate>
> > <NorthBoundingCoordinate>40</NorthBoundingCoordinate>
> > <EastBoundingCoordinate>180</EastBoundingCoordinate>
> > <SouthBoundingCoordinate>-40</SouthBoundingCoordinate>
> > </BoundingRectangle>
> > </HorizontalSpatialDomainContainer>
> > </SpatialDomainContainer>
> > Any suggestion please?
> > Yann
> > gdal-dev mailing list
> > gdal-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
> I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | President OSGeo, http://osgeo.org
