[gdal-dev] ogr2ogr and +towgs84
Frank Warmerdam
warmerdam at pobox.com
Wed Jul 9 17:47:24 EDT 2008
Armin Burger wrote:
> Hi everybody
> I need to convert a shapefile in a UTM projection with datum ED50 to a
> WGS84 based projection (LAEA, Epsg 3035). I applied the datum shift
> parameters using "+towgs84", like
> ogr2ogr -f "ESRI Shapefile" -s_srs "+proj=utm +zone=30 +ellps=intl
> +units=m +towgs84=-131.0,-100.3,-163.4,-1.244,-0.020,-1.144,9.39
> +no_defs" -t_srs "EPSG:3035" with_datumshift test.shp
> but it seems whatever I write for +towgs84 has no effect. I can drop it
> completely or use other values, the result is always the same. Is the
> +towgs84 parameter just not used or do I use a wrong definition somewhere?
> GDAL version used is the one from FWTools 2.1.0 (Win)
Armin,
EPSG:3035 translates as:
PROJCS["ETRS89 / ETRS-LAEA",
GEOGCS["ETRS89",
DATUM["European_Terrestrial_Reference_System_1989",
SPHEROID["GRS 1980",6378137,298.257222101,
AUTHORITY["EPSG","7019"]],
AUTHORITY["EPSG","6258"]],
PRIMEM["Greenwich",0,
AUTHORITY["EPSG","8901"]],
UNIT["degree",0.01745329251994328,
AUTHORITY["EPSG","9122"]],
AUTHORITY["EPSG","4258"]],
UNIT["metre",1,
AUTHORITY["EPSG","9001"]],
PROJECTION["Lambert_Azimuthal_Equal_Area"],
PARAMETER["latitude_of_center",52],
PARAMETER["longitude_of_center",10],
PARAMETER["false_easting",4321000],
PARAMETER["false_northing",3210000],
AUTHORITY["EPSG","3035"],
AXIS["X",EAST],
AXIS["Y",NORTH]]
or in PROJ.4 :
+proj=laea +lat_0=52 +lon_0=10 +x_0=4321000 +y_0=3210000 +ellps=GRS80
+units=m +no_defs
So the problem is that it does not have any datum shift info, and so datum
shifting is disabled in PROJ.4.
If you want to treat EPSG:3035 as being on a WGS84 datum try using:
-t_srs '+proj=laea +lat_0=52 +lon_0=10 +x_0=4321000 +y_0=3210000 +datum=WGS84'
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
