[gdal-dev] Re: [GRASS-user] Using GIMPs Fuzzy Select tool on
orthophotos (geotiff)
Jonathan Greenberg
greenberg at ucdavis.edu
Thu Jul 31 18:51:30 EDT 2008
Nikos:
Have you checked out any of the new minirasterstrip features in
starspan yet? It takes vector data (any format that OGR supports),
extracts a window (user defined size) around the vector out of a set of
rasters (anything that GDAL supports), compiles it into a single image,
and references the original vector data with the new compilation image.
http://starspan.casil.ucdavis.edu
Note: there is a small bug that will be fixed soon with the
referenced vector -- once you get the minirasterstrip raster made,
you'll need to re-define the raster projection to "arbitrary" with the
original pixel size to get the associated vector lined up properly.
--j
P.S. Windows binaries (including an installer) and a java gui are now
part of starspan! Enjoy!
Nikos Alexandris wrote:
> Apologies for cross-posting.
> Can someone tell me why I should NOT use GIMPs "Fuzzy Select" tool to
> select various "features" from an image (e.g. orthophoto), save
> selection in a new file, add geo-metadata from the original image [1]
> and continue my work in GRASS? It works so nice!
> Could a tool like that implemented in GRASS to assist image
> interpretation for example?
> Thank you, Nikos
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Jonathan A. Greenberg, PhD
Postdoctoral Scholar
Center for Spatial Technologies and Remote Sensing (CSTARS)
University of California, Davis
One Shields Avenue
The Barn, Room 250N
Davis, CA 95616
Cell: 415-794-5043
AIM: jgrn307, MSN: jgrn307 at hotmail.com, Gchat: jgrn307
