[gdal-dev] Re: NITF JPEG2000 read support?
Frank Warmerdam
warmerdam at pobox.com
Fri Jun 6 16:30:21 EDT 2008
Sven Geggus wrote:
> Frank Warmerdam <warmerdam at pobox.com> wrote:
>> You would need a license for the Kakadu library though there is a
>> reasonably priced option for personal use.
> Well, it is not personal use, what I intend to do.
>> I have confirmed I can access an NITF file with JPEG2000 imagery using
>> either the JP2KAK (Kakadu) driver, or the JP2ECW (ECW SDK) driver.
> This is indeed a strange thing, because I was unable to use ecwj2 as well,
> as you can see in my original Mail. I think my best bet would be to check my
> file with the FWTools Version of gdalinfo.
Sven,
Well, this is something that could be examined in more detail. JPEG2000
in NITF *can* work with the ECW based driver. With the FWTools build
you can set the GDAL_SKIP environment variable to JP2KAK to avoid the
Kakadu driver if you want to see how the ECW SDK based driver works.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
