[gdal-dev] Polygon winding order in ogrinfo output
Frank Warmerdam
warmerdam at pobox.com
Tue Jun 10 20:18:34 EDT 2008
Roger André wrote:
> Just a quick question to find out how the clockwise winding order is
> established in ogrinfo output. Is this because the original data file
> being read was created with the polygons in that order, or is it a
> "feature" of ogr's?
Roger,
OGR uses the simple features geometry model which places no requirements
on the winding direction of polygon rings. So generally speaking the
winding direction is not defined - often it will be whatever was most
convenient when reading from the source files.
The Shapefile *writer* does have to rewind polygon rings to put them into
the required winding order for shapefiles.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
