[gdal-dev] osm xml and everything else
Tim Bowden tim.bowden at westnet.com.au
Sun Jun 15 09:44:21 EDT 2008
Thanks Martin & Sven, most appreciated.
Regards,
Tim Bowden
On Thu, 2008-06-12 at 12:29 +0000, Martin Spott wrote:
> Tim Bowden wrote:
> > [...] Ultimately, I'm wanting it in postgis where I can make real use of
> > it.  I'd also like to be able to easily suck new data out of postgis
> > into something osm can use.  Recommendations?
> Getting 'foreign' formats into OSM might prove to be challenging ....
> Just to suck small areas into PostGIS I'd say 'osm2pgsql' is your
> friend. If you're just looking for occasional snippets, then I might
> have this download page on offer for you - I'm updating the OSM
> layer(s) approx. every month:
>   http://mapserver.flightgear.org/download.psp
> Cheers,
> 	Martin.
vim is a good example of an IDE done properly.  emacs is an example of
an IDE done poorly.  Anything that involves little pictures is a
mis-umderstanding of what an IDE should be.
