[gdal-dev] Urgent GDal failing to open a file.
Martin Chapman
mchapman at texelinc.com
Fri Jun 20 18:39:18 EDT 2008
If you have control of the code then you could set the projection after the open by calling setProjectionRef().. Just ignore the error if the gdaldataset pointer is not null.
Hope that helps.
Martin
Sent via BlackBerry by AT&T
-----Original Message-----
Date: Fri, 20 Jun 2008 18:23:46
To:gdal-dev at lists.osgeo.org
Subject: [gdal-dev] Urgent GDal failing to open a file.
Good Day list.
I write you with kind of an urgent problem today. The company I am doing some consulting for is using GDAL to read a majority of their data. They just purchased 800$ worth of some GeoData from a third party company. Everytime we try an dopen the data through Gdal I get. A problem with trying to create a Coordinate Transform. See error
ERROR: No PROJ.4 translation for source SRS, coordinate
When I did a Gdal Info on the file. I find this information out
Coordinate System is:
PROJCS[,
GEOGCS["unnamed",
DATUM["unknown",
SPHEROID["unretrievable - using WGS84",6378137,298.257223563]],
PRIMEM["Greenwich",0],
UNIT[,0.0174532925199433]],
UNIT["unknown",1],
AUTHORITY["EPSG","0"]]
Which I think is the root of my problem. Is ther ea good/easy way for me to fix this ? quickly ?
Thanks Court.
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
