[gdal-dev] Urgent GDal failing to open a file.
Frank Warmerdam
warmerdam at pobox.com
Fri Jun 20 18:46:24 EDT 2008
Courtney Schitka wrote:
> Good Day list.
> I write you with kind of an urgent problem today. The company I am doing
> some consulting for is using GDAL to read a majority of their data. They
> just purchased 800$ worth of some GeoData from a third party company.
> Everytime we try an dopen the data through Gdal I get. A problem with
> trying to create a Coordinate Transform. See error
> ERROR: No PROJ.4 translation for source SRS, coordinate
> When I did a Gdal Info on the file. I find this information out
> Coordinate System is:
> PROJCS[,
> GEOGCS["unnamed",
> DATUM["unknown",
> SPHEROID["unretrievable - using WGS84",6378137,298.257223563]],
> PRIMEM["Greenwich",0],
> UNIT[,0.0174532925199433]],
> UNIT["unknown",1],
> AUTHORITY["EPSG","0"]]
> Which I think is the root of my problem. Is ther ea good/easy way for me
> to fix this ? quickly ?
Court,
I *suspect* GDAL is failing to find it's supporting coordinate system
files. Try setting the GDAL_DATA environment variable to point to the
directory with the files like pcs.csv and ecw_cs.wkt.
It would also be helpful if you were able to indicate the file format
with the problem, the version of GDAL, and ideally a sample file.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
