[gdal-dev] Urgent GDal failing to open a file.
Martin Chapman
mchapman at texelinc.com
Fri Jun 20 18:51:53 EDT 2008
Yes, I would try Frank's suggestion first though. If it doesn't work then you could re-write the file and assign a projection with create() or createCopy() on the driver object..
Martin
Sent via BlackBerry by AT&T
-----Original Message-----
Date: Fri, 20 Jun 2008 18:51:24
To:"Frank Warmerdam" <warmerdam at pobox.com>
Cc:gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] Urgent GDal failing to open a file.
Frank & Martian
Thanks for your prompt replies.
If I know the coordinate system the file is supposed to be, is there a way I can inject that into the file it's self ? Without needing to edit the code or setting the GDAL_DATA environment variable ? The file is a GeoTiff ? I'd provide a sample but the file is 100+ M could take a bit.
Court
On Fri, Jun 20, 2008 at 6:46 PM, Frank Warmerdam <warmerdam at pobox.com <mailto:warmerdam at pobox.com> > wrote:
Courtney Schitka wrote:
Good Day list.
I write you with kind of an urgent problem today. The company I am doing some consulting for is using GDAL to read a majority of their data. They just purchased 800$ worth of some GeoData from a third party company. Everytime we try an dopen the data through Gdal I get. A problem with trying to create a Coordinate Transform. See error
ERROR: No PROJ.4 translation for source SRS, coordinate
When I did a Gdal Info on the file. I find this information out
Coordinate System is:
PROJCS[,
GEOGCS["unnamed",
DATUM["unknown",
SPHEROID["unretrievable - using WGS84",6378137,298.257223563]],
PRIMEM["Greenwich",0],
UNIT[,0.0174532925199433]],
UNIT["unknown",1],
AUTHORITY["EPSG","0"]]
Which I think is the root of my problem. Is ther ea good/easy way for me to fix this ? quickly ?
Court,
I *suspect* GDAL is failing to find it's supporting coordinate system
files. Try setting the GDAL_DATA environment variable to point to the
directory with the files like pcs.csv and ecw_cs.wkt.
It would also be helpful if you were able to indicate the file format
with the problem, the version of GDAL, and ideally a sample file.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at pobox.com <mailto:warmerdam at pobox.com>
light and sound - activate the windows | http://pobox.com/~warmerdam <http://pobox.com/%7Ewarmerdam>
and watch the world go round - Rush | President OSGeo, http://osgeo.org <http://osgeo.org>
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
