[gdal-dev] Ubuntu, gdal & ecw's >2gb on IA32
Lucena, Ivan ivan.lucena at pmldnet.com
Sat Jun 21 01:47:13 EDT 2008
Oh. I got it. So, the file size restriction on the "unpaid" license is not hard coded anymore. Good to know. Thanks.
>  -------Original Message-------
>  From: Tim Bowden <tim.bowden at westnet.com.au>
>  Subject: Re: [gdal-dev] Ubuntu, gdal & ecw's >2gb on IA32
>  Sent: Jun 21 '08 05:41
>  On Sat, 2008-06-21 at 05:26 +0000, Lucena, Ivan wrote:
>  > For a long time I don't deal with ECW but isn't it a matter of file
>  >  size limitation on the *free* ECW library? Regards.
>  The size limit is a licensing issue, not a technical one; Same code
>  either way.  Besides, the "free" license is a long way from being free
>  in any meaningful way.
>  Regards,
>  Tim Bowden
>  > >  Subject: [gdal-dev] Ubuntu, gdal & ecw's >2gb on IA32
>  > >  Sent: Jun 21 '08 02:14
>  > >  I've got a bit of a problem with ecw's on ubuntu 8.04; gdal can't read
>  > >  them if they're >2gb in size, but there's no problem with the same setup
>  > >  on ubuntu 7.10.
>  > >  Details:
>  > >  Ubuntu 7.10
>  > >  gcc --version
>  > >  gcc (GCC) 4.1.3 20070929 (prerelease) (Ubuntu 4.1.2-16ubuntu2)
>  > >  ubuntu gcc package: 4.1.2-9ubuntu2
>  > >  kernel: ubuntu packaged 2.6.22-14-generic
>  > >  glibc: 2.6.1-1ubuntu9
>  > >  Ubuntu 8.04
>  > >  gcc --version
>  > >  gcc (GCC) 4.2.3 (Ubuntu 4.2.3-2ubuntu7)
>  > >  ubuntu gcc package: 4.2.3-1ubuntu3
>  > >  kernel: ubuntu packaged 2.6.24-19-generic
>  > >  glibc: 2.7-10ubuntu3
>  > >  On both PC's (from source):
>  > >  gdal: gdal-1.5.2
>  > >  ecw: libecwj2-3.3
>  > >  The binary FWTools dist exhibits the same outcomes- works on bunty 7.10,
>  > >  fails on 8.04 for ecw's >2gb.
>  > >  I'm not at all sure where it may be going wrong, but having a wild
>  > >  guess, I'd think either kernel, glibc or something else.
>  > >  Can anyone replicate these results?
>  > >  Does anyone have any ideas as to what's going on, and more importantly,
>  > >  how to fix it?
>  > >  Thanks,
>  > >  Tim Bowden
>  > >  _______________________________________________
>  > >  gdal-dev mailing list
>  > >  gdal-dev at lists.osgeo.org
>  > >  http://lists.osgeo.org/mailman/listinfo/gdal-dev
>  vim is a good example of an IDE done properly.  emacs is an example of
>  an IDE done poorly.  Anything that involves little pictures is a
>  mis-umderstanding of what an IDE should be.
