[gdal-dev] WKT recognition problem with some Polish prj files
Markus Neteler neteler at osgeo.org
Sat Jun 21 09:04:02 EDT 2008
attached PUWG_1965_Strefa_I.prj isn't properly recognized in GRASS
(which uses OGR for that). The file was given to me as official WKT file
during the cascadoss.eu workshop. The problem seems to be
  PROJECTION["Double_Stereographic"]
which should be probably
  PROJECTION["Stereographic"]
only?
(related discussion I found in
 http://article.gmane.org/gmane.comp.gis.grass.user/17053
In a presentation from FrankW I found:
Warmerdam:
 Stereographic
Aka Oblique Stereographic
 +proj=stere +lat_0=<origin lat>
 +lon_0=<origin long> +k=<scale factor>
 +x_0=<false easting> +y_0=<false northing>
Example (Poland Zone 1):
 +proj=stere +lat_0=50d37.5 +lon_0=21d5
 +k=0.9998 +x_0=4637000 +y_0=5647000
 +ellps=krass +units=m
 +towgs84=33.4,-146.6,-76.3,-0.359,-0.053,0.844,-0.84
replacing
-> PROJECTION["Stereographic"]
seems to solve it.
Another one I found is:
PROJCS["UWPP_1992",
GEOGCS["GCS_ETRF_1989",
DATUM["D_ETRF_1989",
SPHEROID["WGS_1984",6378137.0,298.257223563]],
PRIMEM["Greenwich",0.0],
UNIT["Degree",0.0174532925199433],
AXIS["Longitude",EAST],
AXIS["Latitude",NORTH]],
PROJECTION["Gauss-Kruger"],
PARAMETER["False_Easting",500000.0],
PARAMETER["False_Northing",-5300000.0],
PARAMETER["Central_Meridian",19.0],
PARAMETER["Scale_Factor",0.9993],
PARAMETER["Latitude_Of_Origin",0.0],
UNIT["Metre",1.0],
AXIS["x",EAST],
AXIS["y",NORTH]]
where
should be
  PROJECTION["Transverse_Mercator"]
Can we auto-mangle that in OGR?
In GRASS we have support to fix broken datum names but
no way to do the same for PROJECTION since OGR does the
parsing for us.
thanks
Markus
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20080621/d8a10ded/PUWG_1965_Strefa_I.obj
