[gdal-dev] Ubuntu, gdal & ecw's >2gb on IA32
Tim Bowden
tim.bowden at westnet.com.au
Sun Jun 22 14:25:13 EDT 2008
Fix found by FrankW on irc. See http://trac.osgeo.org/gdal/ticket/2437
for bug report and solution.
Thanks all for assistance in sorting this one.
Tim Bowden
On Sun, 2008-06-22 at 23:47 +0800, Tim Bowden wrote:
> On Sun, 2008-06-22 at 05:45 -0600, Richard Greenwood wrote:
> > On Sat, Jun 21, 2008 at 10:28 PM, Tim Bowden <tim.bowden at westnet.com.au> wrote:
> > > On Sat, 2008-06-21 at 18:13 -0400, Marius Jigmond wrote:
> > >> Tim Bowden wrote:
> > >> > On Sat, 2008-06-21 at 09:09 -0600, Richard Greenwood wrote:
> > >> > > On Sat, Jun 21, 2008 at 9:00 AM, Tim Bowden <tim.bowden at westnet.com.au> wrote:
> > >> > > > *me scratches head* and not for the first time. I wasn't expecting that
> > >> > > > to make a difference. No idea what to make of it. Just to make sure
> > >> > > > I've got it right, the samba share was being served from a mac was it?
> > >> > > > And you were running gdalinfo from ubuntu 8.04? or the other way
> > >> > > > around?
> > >> > > I'm running 32 bit Ubuntu Hardy 8.04. I had a Windows XP NTFS drive
> > >> > > mounted via Samba and gdalinfo was fine. Copied the same file to the
> > >> > > local ext3 partition and got the error. I'll be trying the same file
> > >> > > on a Slackware server in the next couple days.
> > >> > Ah, perhaps it's worth trying on a non ext3 filesystem. Not sure how it
> > >> > would make a difference, but I've got no other ideas.
> > >> > > Obviously a work around is to split the ecw file into tiles.
> > >> > Ugly solution for me. I've got (client rather) abt 350gb+ of ecw's
> > >> > mostly over 2gb each being served up by mapserver that will be updated
> > >> > every three months . Hate to have to automate that in a failsafe way.
> > >> > Tim
> > >> > > Rich
> > >> This might be related to a similar issue I had reading tiff's larger
> > >> than 2GB also on Ubuntu 8.04. I have the exact same error, while it
> > >> works on Ubuntu 7.10. I never got to the bottom of it, but I suspect
> > >> something is broken in Ubuntu 8.04.
> > >> Marius
> > > I just got the same result with a geotiff >2gb. I think we can say
> > > libecwj is in the clear for now.
> > > Richard, is your slackware ext3?
> > No. It is reiserfs.
> I've just tried reiserfs on ubuntu 8.04 and there is no change in the
> problem. I'm going to chase this one up in bunty land, as it seems
> clear this is an ubuntu specific problem. I'll report back if I ever
> get to the bottom of it.
> Regards,
> Tim Bowden
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
vim is a good example of an IDE done properly. emacs is an example of
an IDE done poorly. Anything that involves little pictures is a
mis-umderstanding of what an IDE should be.
