[gdal-dev] GDAL 1.5+ and MrSID
Howard Butler
hobu.inc at gmail.com
Fri Jun 27 12:38:05 EDT 2008
Actually, I misspoke about no JP2 in 7.0. It's there, but it changed
quite significantly and GDAL maybe hasn't been updated to use it quite
yet.
http://trac.osgeo.org/gdal/ticket/2410
I think the plan is for 1.6 to be released sometime this fall, but we
haven't started the planning process for 1.6 yet. Frank could comment
on what his expectations are for 1.6...
Howard
On Jun 27, 2008, at 10:44 AM, Nidel, Mike wrote:
> That's a good start. Like I said, it seems to work with 1.5 branch
> but I just wasn't sure about the libtool issue. I didn't have to
> configure with --with-jp2mrsid=no for some reason, although I did
> read about how the JP2 support isn't there anymore in 7.0.
> For now, since I have 1.5 working with the imageio-ext library,
> I'm going to continue down the path I was on.
> I take it the trunk is 1.6? Is there any plan to release an official
> version of 1.6 soon?
> thanks for the reply,
> Mike
>> -----Original Message-----
>> From: Howard Butler [mailto:hobu.inc at gmail.com]
>> Sent: Friday, June 27, 2008 11:32 AM
>> To: Nidel, Mike
>> Cc: gdal-dev at lists.osgeo.org
>> Subject: Re: [gdal-dev] GDAL 1.5+ and MrSID
>> On Jun 27, 2008, at 9:49 AM, Nidel, Mike wrote:
>>> I've been following a few of the threads online regarding building
>>> GDAL on MrSID 7.0, and the various issues that have cropped up. It
>>> seems like the latest revisions to get MrSID 7 working with
>> 1.5+ are
>>> in the 1.5 branch, but not in any tag (e.g. 1.5.2, the
>> latest 1.5.x I
>>> saw). So one question is, is there any plan to release a
>> 1.5.3 soon,
>>> with support for MrSID 7.0?
>> Mike,
>> Just two days ago I compiled MrSID 7.0 on x86_64 against
>> trunk and it worked quite well. Give that combination a try
>> and see if you can
>> make any progress. You'll have to say --with-jp2mrsid=no
>> because the
>> 7.0 SDK doesn't have JP2 in it.
>> Howard
> gdal-dev mailing list
