[gdal-dev] GDAL 1.5+ and MrSID
Nidel, Mike
mike.nidel at lmco.com
Fri Jun 27 11:44:04 EDT 2008
That's a good start. Like I said, it seems to work with 1.5 branch
but I just wasn't sure about the libtool issue. I didn't have to
configure with --with-jp2mrsid=no for some reason, although I did
read about how the JP2 support isn't there anymore in 7.0.
For now, since I have 1.5 working with the imageio-ext library,
I'm going to continue down the path I was on.
I take it the trunk is 1.6? Is there any plan to release an official
version of 1.6 soon?
thanks for the reply,
Mike
> -----Original Message-----
> From: Howard Butler [mailto:hobu.inc at gmail.com]
> Sent: Friday, June 27, 2008 11:32 AM
> To: Nidel, Mike
> Cc: gdal-dev at lists.osgeo.org
> Subject: Re: [gdal-dev] GDAL 1.5+ and MrSID
> On Jun 27, 2008, at 9:49 AM, Nidel, Mike wrote:
> > I've been following a few of the threads online regarding building
> > GDAL on MrSID 7.0, and the various issues that have cropped up. It
> > seems like the latest revisions to get MrSID 7 working with
> 1.5+ are
> > in the 1.5 branch, but not in any tag (e.g. 1.5.2, the
> latest 1.5.x I
> > saw). So one question is, is there any plan to release a
> 1.5.3 soon,
> > with support for MrSID 7.0?
> Mike,
> Just two days ago I compiled MrSID 7.0 on x86_64 against
> trunk and it worked quite well. Give that combination a try
> and see if you can
> make any progress. You'll have to say --with-jp2mrsid=no
> because the
> 7.0 SDK doesn't have JP2 in it.
> Howard
