[gdal-dev] The proj.dll mistery
Frank Warmerdam
warmerdam at pobox.com
Mon Jun 30 19:53:00 EDT 2008
Joaquim Luis wrote:
> Hi,
> OK, I recovered from a mysterious sudden stop working of my gdalwarp
> and ogrproj MEX files. All I had were error messages like
> "Failed to create coordinate transformation between the
> following coordinate systems. This may be because they
> are not transformable, or because projection services
> (PROJ.4 DLL/.so) could not be loaded."
> But not long ago those worked ok. It turn out that probably the culprit
> was the "VantagePoint" here pointed out recently, that installed an
> older (incompatible??) version of proj.dll on "C:\WINDOWS\system32" (I
> hate softs that do it).
> When I have dll conflicts, I always use the Dependency Walker to help me
> out, but in this case (an others??) the gdal.dll (trunk version) didn't
> show up any dependency on proj.dll. So it was a matter of "and what if
> it is in system32?" lucky guess that allowed me to solve the problem.
> There are plenty of dll dependencies on gdal.dll. Why not on proj.dll?
Joaquim,
For better or worse, many years ago I had the bright idea of making PROJ.DLL
(or libproj.so) demand loaded when needed so that it wouldn't be a "hard"
dependency of GDAL making it harder for people to get things built. So
it does not show up as a dependency. This is similar to how plugins are
handled. They also won't show up.
It seems to me that the error message was pretty specific about what went
wrong.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
