[gdal-dev] The proj.dll mistery
Mon Jun 30 20:31:05 EDT 2008
Joaquim Luis wrote:
> Frank Warmerdam wrote:
>> Joaquim,
>> For better or worse, many years ago I had the bright idea of making
>> PROJ.DLL
>> (or libproj.so) demand loaded when needed so that it wouldn't be a "hard"
>> dependency of GDAL making it harder for people to get things built.  So
>> it does not show up as a dependency.  This is similar to how plugins are
>> handled.  They also won't show up.
> Frank,
> So what is the purpose of this section in nmake.opt?
> I tried with it uncommented but it made no difference.
> # PROJ.4 stuff
> # Uncomment the following lines to link PROJ.4 library statically.
> Otherwise
> # it will be linked dynamically during runtime.
> #PROJ_FLAGS = -DPROJ_STATIC
> #PROJ_INCLUDE = -IC:\programs\proj4\proj-4.6.0\bin
> #PROJ_LIBRARY = C:\programs\proj4\proj-4.6.0\bin\proj_i.lib
Joaquim,
This is an alternative to dynamically loading PROJ.4.  You might
find you need to do a clean build with these options uncommented.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
