[gdal-dev] Re: gdalwarp: ERROR 1: TIFFFetchStripThing:Sanity
check on size of "StripOffsets" value failed
Even Rouault
even.rouault at mines-paris.org
Fri Mar 7 13:49:46 EST 2008
Wolfgang,
I thought I already replied to a similar problem a few days ago, saying that
reminds me strongly of this bug : http://trac.osgeo.org/gdal/ticket/2005.
You can try to play with the BLOCKXSIZE and BLOCKYSIZE creation options, that
is to say make them bigger than their default values. See case 4) of the bug
description.
Or you can either try to patch the function in libtiff mentionned in the
ticket...
Best regards,
Even
Le Friday 07 March 2008 11:51:45 WolfgangZ, vous avez écrit :
> John Mitchell schrieb:
> > It appears that the below error is not preventing the gdalwarp
> > processing from running but is the below error something to be concerned
> > about?
> > Thanks,
> > John
> > On Dec 27, 2007 9:20 AM, John Mitchell < mitchelljj98 at gmail.com
> > <mailto:mitchelljj98 at gmail.com>> wrote:
> > Hi,
> > When running the below command:
> > gdalwarp.exe --config GDAL_CACHEMAX 250 -wm 250 -wo
> > SKIP_NOSOURCE=YES -tr 1.1994660564E-5 1.1994660564E-5 -srcnodata "0
> > 0 0" -dstnodata "0 0 1" -rc -s_srs EPSG:26911 -t_srs EPSG:4326 -co
> > bigtiff=yes -q --optfile
> > x:\ProcessingControl\gvwkr02\gvApp2\tmp\inputFiles.txt
> > "x:\ProcessingControl\gvwkr02\gvApp2\tmp\mosaic_0_161039.tiftemp"
> > I get the following error:
> > ERROR>ERROR 1: TIFFFetchStripThing:Sanity check on size of
> > I have run similar gdalwarp commands against other datasets and have
> > not had this error. Also when I run gdalwarp against each one of
> > these files (that
> > x:\ProcessingControl\gvwkr02\gvApp2\tmp\inputFiles.txt is
> > referencing) individually I get no error.
> > Any ideas on what this error means?
> > Do I have to split up the above gdalwarp mosaicking process into 2
> > parts and then mosaic then back together in order to get around this
> > error, or would increasing the RAM, hard drive space, etc. help to
> > get around this error?
> > Thanks,
> > John J. Mitchell
> > John J. Mitchell
> I also get this error message but from gdal_translate
> Here the command line output:
> Z:\Spain>gdal_translate -co BIGTIFF=YES -co TILED=YES -co COMPRESS=JPEG
> Spain.vrt Spain.tif
> Input file size is 458752, 385024
> ERROR 1: TIFFFetchStripThing:Sanity check on size of "TileOffsets" value
> failed
> 0ERROR 1: TIFFFetchStripThing:Sanity check on size of "TileOffsets"
> value failed
> failed
> I tried FWTools 2.06 on linux 2.11 on windows.
> Any ideas?
> Regards
> Wolfgang
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
