[gdal-dev] Google SoC idea...
ivan.lucena at pmldnet.com
Tue Mar 18 21:05:31 EDT 2008
Hi Yann,
I guess I am looking to some very boring thumbnails when I look to my datasets in 100x100.
Other interesting features on Windows Explorer is the "FilmStrip" where you have a bigger picture on top and the others as thumbnails aligned like picture frames.
In both modes, thumbnail or filmstrip, users can right-click and open the file properties/summary where I believe you can inject some metadata.
I believe that by the COM Shell API extension you can have all those features at the same time. No?
Best regards,
Ivan
> -------Original Message-------
> From: Yann Chemin <yann.chemin at gmail.com>
> Subject: Re: [gdal-dev] Google SoC idea...
> Sent: Mar 14 '08 04:34
> Yes Ivan,
> was not sure about who could be doing it even, it was just an idea about
> improving KDE thumbnail for GIS, since gdal_translate has it already it
> should be just few code away though.
> About the RS image display, gdal_translate outputs nice PNGs, we can tell
> easily if data is landsat (number of bands) and make a standard false
> colour composite (FCC) by selecting bands 4,3,2 for RGB.
> For AVHRR: 4,2,1 for RGB. Well, maybe use the metadata to tell us what
> satellite and what are the band representing, and then make FCC.
> Could also have world countries, major rivers, (degree grid?) etc vectors
> overlaid on the fly while creating the thumbnail...
> Just sending out ideas.....
> Yann
> On 14/03/2008, LUCENA, IVAN <[LINK: mailto:ivan.lucena at pmldnet.com]
> ivan.lucena at pmldnet.com> wrote: Yann,
> I think that is OK to do that. I don't want to discourage you but
> just
> keep in mind that sometime, or very often, GIS/RS image are not very
> expressive by itself. That is even worse in low resolution thumbnail.
> Imagine that you want to show a collection of Landsat original
> multi-band files. Which band should you present in KDE or Explorer?
> Try that: Run "foreach" or "for %f in" to call gdal_translate to copy
> large group of real-case-GIS/RS-files to PNG outputs files in another
> directory. Then open that directory on a file browser and take a look at
> those thumbnails. See how does it looks like.
> Best regards,
> Ivan
> Yann Chemin wrote:
> > Hi list,
> > It may be a small thing but it might help people...
> > many OSs now have image browsers embedded. in MS it is in Explorer I
> > believe, in KDE there is a thumbnail creator inside konqueror/dolphin.
> > could it be possible to make konqueror/dolphin for example,
> automatically
> > create a thumbnail of RS images and GIS covers through GDAL?
> > We could then have GIS/RS data previews the same way we have for
> standard
> > camera pictures...
> > thanks,
> > Yann
> > gdal-dev mailing list
> > [LINK: mailto:gdal-dev at lists.osgeo.org] gdal-dev at lists.osgeo.org
> > [LINK: http://lists.osgeo.org/mailman/listinfo/gdal-dev]
