[gdal-dev] Urgent :: gdal_translate Solution
SriRam Prasad Bhasker SriRam.PrasadBhasker at rmsi.com
Mon Mar 31 07:36:26 EDT 2008
Hi.
Whenever i use Gdal_Translate with the below Syntax the Monochrome 1 BIT
image is getting converted tgo 8 BIT Image.
Is there any Way to ensure the BPP values [Bits per Pixel] value remain
the same even after translation.
gdal_translate -of gtiff -co Compress=LZW input.tif output.tif
presently input.tif = 1 Bit Image
Output is coming as 8 BIT Image
Bhasker
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20080331/12cc7d31/attachment.html
