[gdal-dev] Building OGDI
Courtney Schitka
c.schitka at gmail.com
Mon May 5 12:35:58 EDT 2008
Martin,
That's what I am doing. Here's the procedure I am following.
1. Launch a VS Command Shell.
2. Run VCVars32.bat to set the environment
3. Start Cygwin
4. Change to the directory containing my sources
5. Set up the variables via EXPORT command
6. Run make
Then I get that paritcular message as I was talking about earlier. Is this
how you compile it ?
FYI. When I edit the varwin32.bat file with the appropriate paths etc. Then
Run it, it starts a bash shell via cygwin and I get the same problem. Not
that important I am just stating it incase that's the next thing that is
suggested. I've been down that road.
Court
On Mon, May 5, 2008 at 12:31 PM, Martin Chapman <mchapman at texelinc.com>
wrote:
> Download Cygwin and use that to compile it on windows. That's what I do
> and it works great.
> Martin
> *From:* gdal-dev-bounces at lists.osgeo.org [mailto:
> gdal-dev-bounces at lists.osgeo.org] *On Behalf Of *Courtney Schitka
> *Sent:* Monday, May 05, 2008 10:03 AM
> *To:* Mateusz Loskot
> *Cc:* gdal-dev at lists.osgeo.org
> *Subject:* Re: [gdal-dev] Building OGDI
> Hi Mateusz,
> Yes those were the first things I tried before writing the list. When I
> try and build using the instructions off the website..... I get
> make: *** No rule to make target
> C:/downloads/OGDI_NEW/ogdi3.2.0.beta1/ogdi-3.2.0.beta1/config/common.mak.
> Stop. So I was wondering if anyone else had seen this behaviour and knew
> what the problem was.
> Courtney
> On Mon, May 5, 2008 at 11:49 AM, Mateusz Loskot <mateusz at loskot.net>
> wrote:
> Courtney Schitka wrote:
> Hi,
> Does anyone know of or can anyone point me at build instructions for
> building OGDI-beta2 on Windows using any of the dev studio/command prompt
> shells environments. I really don't care what version of MS DevStudio I
> use
> I just need some build instructions that actually work on Windows.
> Have you tried to follow the instructions from the OGDI website?
> http://ogdi.sourceforge.net/build.html
> Greetings
> Mateusz Loskot
> http://mateusz.loskot.net
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20080505/084bd1ac/attachment.html
