[gdal-dev] Building OGDI
Martin Chapman
mchapman at texelinc.com
Mon May 5 12:41:19 EDT 2008
When you installed Cygwin did you select all the options for the compiler?
I had to go back to the cygwin install and reinstall before it worked for me
because the first time I installed it I did not install everything.
Martin
From: Courtney Schitka [mailto:c.schitka at gmail.com]
Sent: Monday, May 05, 2008 10:36 AM
To: Martin Chapman
Cc: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] Building OGDI
Martin,
That's what I am doing. Here's the procedure I am following.
1. Launch a VS Command Shell.
2. Run VCVars32.bat to set the environment
3. Start Cygwin
4. Change to the directory containing my sources
5. Set up the variables via EXPORT command
6. Run make
Then I get that paritcular message as I was talking about earlier. Is this
how you compile it ?
FYI. When I edit the varwin32.bat file with the appropriate paths etc. Then
Run it, it starts a bash shell via cygwin and I get the same problem. Not
that important I am just stating it incase that's the next thing that is
suggested. I've been down that road.
Court
On Mon, May 5, 2008 at 12:31 PM, Martin Chapman <mchapman at texelinc.com>
wrote:
Download Cygwin and use that to compile it on windows. That's what I do and
it works great.
Martin
[mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Courtney Schitka
Sent: Monday, May 05, 2008 10:03 AM
To: Mateusz Loskot
Hi Mateusz,
Yes those were the first things I tried before writing the list. When I try
and build using the instructions off the website..... I get
make: *** No rule to make target
C:/downloads/OGDI_NEW/ogdi3.2.0.beta1/ogdi-3.2.0.beta1/config/common.mak.
Stop. So I was wondering if anyone else had seen this behaviour and knew
what the problem was.
Courtney
On Mon, May 5, 2008 at 11:49 AM, Mateusz Loskot <mateusz at loskot.net> wrote:
Courtney Schitka wrote:
Does anyone know of or can anyone point me at build instructions for
building OGDI-beta2 on Windows using any of the dev studio/command prompt
shells environments. I really don't care what version of MS DevStudio I use
I just need some build instructions that actually work on Windows.
Have you tried to follow the instructions from the OGDI website?
http://ogdi.sourceforge.net/build.html
Greetings
Mateusz Loskot
http://mateusz.loskot.net <http://mateusz.loskot.net/>
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20080505/ff4f47e1/attachment-0001.html
