[gdal-dev] need help with gdalwarp
Wendell Turner
wendell at enflight.com
Wed May 7 14:06:56 EDT 2008
I'm new to gdal an have a question about warping an image
that I would like help with.
I have a GeoTIFF image of a Lambert Conformal Conic
projection of a map. I would like to convert it to Mercator
(so the longiude lines are parallel, and the latitude lines
are straight). Does gdalwarp do this? What are the
parameters for the projections? Do I need to tell it the
source and target spatial reference set? What other options
should I send to gdalwarp?
Thanks,
Wendell
