[gdal-dev] need help with gdalwarp
Frank Warmerdam
warmerdam at pobox.com
Wed May 7 14:26:12 EDT 2008
Wendell Turner wrote:
> Hi,
> I'm new to gdal an have a question about warping an image
> that I would like help with.
> I have a GeoTIFF image of a Lambert Conformal Conic
> projection of a map. I would like to convert it to Mercator
> (so the longiude lines are parallel, and the latitude lines
> are straight). Does gdalwarp do this? What are the
> parameters for the projections? Do I need to tell it the
> source and target spatial reference set? What other options
> should I send to gdalwarp?
Wendell,
Yes, gdalwarp is the appropriate tool.
Does GDAL recognise the coordinate system of the source image? Try
a "gdalinfo" on it, and see if there is a coordinate system description.
If so, it might be sufficient to do something like:
gdalwarp src.tif -t_srs '+proj=merc +datum=WGS84' dst.tif
You might find some of the following helpful to understand coordinate systems
in GDAL/OGR a bit.
http://www.gdal.org/ogr/osr_tutorial.html
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
