[gdal-dev] Add a new filed to an existing shapefile
Mateusz Loskot
mateusz at loskot.net
Fri May 16 10:08:32 EDT 2008
On May 16, 2008, at 3:19 PM, Limei Ran wrote:
> //create weight item to the attribute
> OGRFieldDefn oField( itemName.c_str(), OFTReal);
> printf ("\tBuiled field item: %s\n", itemName.c_str() );
> if( poLayer->CreateField( &oField, TRUE ) != OGRERR_NONE )
> printf( "\tFailed to create field: %s\n",itemName.c_str() );
> exit( 1 );
Limei,
If you are trying to add field to a non-empty shapefile with features,
then it won't work.
From the OGR tutorial [1]:
"Fields must be added to the layer before any features are written."
[1] http://gdal.org/ogr/ogr_apitut.html
Mateusz Loskot, http://mateusz.loskot.net
Charter Member of OSGeo, http://osgeo.org
