[gdal-dev] Add a new filed to an existing shapefile
Frank Warmerdam
warmerdam at pobox.com
Fri May 16 10:15:27 EDT 2008
Limei Ran wrote:
> Hi:
> I am trying to add a new double field to an existing shapefile using the
> following codes. But, poLayer->CreateField failed. Could you tell me
> what is wrong with the codes?
Limei,
I believe the shapefile driver does not support adding fields to a shapefile
layer that already has records/features in it. This is fairly common in file
based drivers, though it *could* be implemented for shapefiles if there was
sufficient need.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
