[gdal-dev] OGR's GMT driver: requests for enhancement
Bruce Raup
brauplists at gmail.com
Fri May 16 18:29:56 EDT 2008
Hi all (and Frank),
I've been trying to use ogr2ogr to create a shapefile from a GMT text
file. I created the GMT file with the enhanced comment fields to
define the attribute names, types, etc. using perl. The problem is
that ogr2ogr defines all the string fields as 80 characters in width.
Is there some control over this? I have a "description" field that is
getting truncated.
Thanks,
Bruce
Bruce Raup
http://cires.colorado.edu/~braup/
