[Gdal-dev] building gdal with local xerces/proj4
Mateusz Loskot
mateusz at loskot.net
Tue May 27 09:55:17 EDT 2008
On May 27, 2008, at 12:11 PM, VJorg wrote:
> Hello,
> I'm trying to build a gdal 1.5.1 using a local version of Xerces
> 2.7.0 and
> Proj 4 4.6.0 (despite the fact that both are installed on the
> system, but we
> wish to be independant of it). I'm using Xerces 2.7.0, as
> compilation with
> 2.8.0 fails ( http://trac.osgeo.org/gdal/ticket/2370 ticket 2370 ),
> but that
> is a different issue. For this purpose, I have build xerces and
> proj4 in
> /home/jv/thirdparty/xerces/xerces-c-src_2_7_0 and
> /home/jv/thirdparty/proj/proj4.6.0 respectively.
Jorg,
I assume you are using GCC on Linux.
> The configure step is
> ./configure --prefix=/home/jv/thirdparty/linuxbuilds/gdal151 --
> enable-rtti
> --with-static-proj4=/home/jv/thirdparty/proj/proj4.6.0
> --with-xerces=/home/jv/thirdparty/xerces/xerces-c-src_2_7_0
> In the output, it shows:
> checking for Xerces C++ Parser headers in
> /home/jv/thirdparty/xerces/xerces-c-src_2_7_0/include and
> /home/jv/thirdparty/xerces/xerces-c-src_2_7_0/include/xercesc... found
> checking for Xerces C++ Parser libraries... found
> checking for Xerces C++ Parser... yes
> checking if Xerces C++ Parser version is >= 2.7.0... yes
This looks OK so far.
> The compilation output however shows (just one example)
> libtool: link: g++ ogr2ogr.o -o .libs/ogr2ogr
> /home/jv/thirdparty/gdal/gdal-1.5.1/.libs/libgdal.so
> -L/home/jv/thirdparty/proj/proj4.6.0/src -L/usr/lib
> -L/home/jv/thirdparty/xerces/xerces-c-src_2_7_0/lib /usr/lib/
> libproj.so
> /usr/lib/libsqlite3.so /usr/lib/libodbc.so /usr/lib/libodbcinst.so
> /usr/lib/libexpat.so -lxerces-c -lpthread /usr/lib/libjasper.so
> /usr/lib/libhdf5.so -logdi31 -lgif -lgeotiff /usr/lib/libtiff.so -lm
> -lc
> /usr/lib/libjpeg.so -lpng -lnetcdf -lcfitsio -lpq -lz -lrt -ldl -Wl,-
> rpath
> -Wl,/home/jv/thirdparty/linuxbuilds/gdal151/lib
> and further
> libtool: link: g++ ogrtindex.o -o .libs/ogrtindex
> libproj.so
> -lc
> rpath
> Why does it look in proj4.6.0/src for linkage?
This is an intentional exception. Comments to the ticket 1345 should
be helpful:
http://trac.osgeo.org/gdal/ticket/1345
and here:
http://trac.osgeo.org/gdal/ticket/1538#comment:6
> All the libraries it needs
> are in the (default) proj4.6.0/src/.libs ... How can I change this?
I'm not sure it's possible.
> It hasn't it used the libxerces-s.so.27 that is present in
> -L/home/jv/thirdparty/xerces/xerces-c-src_2_7_0/lib, presumably as the
> /usr/lib path is listed first... How can I overcome this order?
The libraries are scanned in order from left to right, however
standard paths seem to have higher priority than those given with -L
option.
The xerces issue is IMO ldd problem but not GCC linker problem, see
below.
> When checking out the libgdal.so library using ldd, it shows
> dependancies
> from
> libproj.so.0 => /usr/lib/libproj.so.0
> libxerces-c.so.27 => /usr/lib/libxerces-c.so.27
Try to temporarily rename libxerces-c.so.27
sudo mv /usr/lib/libxerces-c.so.27 /usr/lib/libxerces-c.so.27-disabled
and then run ldd.
Assuming you have the /home/jv/thirdparty/xerces/xerces-c-src_2_7_0/
lib in LD_LIBRARY_PATH, system should search for xerces in the custom
location instead of /usr/lib.
Linker does not put full patch to the .so library in the output
executable,
but only the name of .so file. So, this is not a compilation issue but
run-time loading. By default, system searches only /lib and /usr/lib.
Mateusz Loskot, http://mateusz.loskot.net
Charter Member of OSGeo, http://osgeo.org
