[Gdal-dev] building gdal with local xerces/proj4
VJorg jorg.verstraete at incgeo.be
Tue May 27 10:18:41 EDT 2008
Mateusz Loskot wrote:
>> Why does it look in proj4.6.0/src for linkage?
> This is an intentional exception. Comments to the ticket 1345 should
> be helpful:
Indeed... Thanks!
> Try to temporarily rename libxerces-c.so.27
ldd shows that the library is missing...
> Assuming you have the /home/jv/thirdparty/xerces/xerces-c-src_2_7_0/
> lib in LD_LIBRARY_PATH, system should search for xerces in the custom
> location instead of /usr/lib.
The configure step consistenly fails whenever I try to use LD_LIBRARY_PATH.
But I manage to get it working using the LDFLAGS. :)
Jörg
View this message in context: http://www.nabble.com/building-gdal-with-local-xerces-proj4-tp17486002p17491521.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
