[gdal-dev] Compiling GDAL-1.5.1 on Linux
Frank Warmerdam
warmerdam at pobox.com
Tue May 27 12:21:08 EDT 2008
Lucena, Ivan wrote:
> Frank,
> I didn't mentioned before but I also tried --disable-curl --disable-wms --disable-wcs. In the meantime I decided to try the 151RC1
> But the "--without-curl" worked fine. It shows on the final ./confure report that the OGC services are disabled.
> The version og cURL that I have here is:
> $ curl-config --version
> libcurl 7.10.6
> I can add a ticked for that, sure.
> Continuing the build the process I am facing another error:
> kml.h:41:2: #error "Old version of expat, please upgrade to expat 2.x"
> I will try --without-kml ?
Ivan,
I think you will want to do "--without-expat"
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
