[gdal-dev] Compiling GDAL-1.5.1 on Linux
Lucena, Ivan
ivan.lucena at pmldnet.com
Wed May 28 00:18:36 EDT 2008
Frank,
I tried that:
% ./configure --without-curl --without-expat
% make
And it worked.
Thanks,
Ivan
Frank Warmerdam wrote:
> Lucena, Ivan wrote:
>> Frank,
>> I didn't mentioned before but I also tried --disable-curl
>> --disable-wms --disable-wcs. In the meantime I decided to try the 151RC1
correction: 152RC1
>> But the "--without-curl" worked fine. It shows on the final ./confure
>> report that the OGC services are disabled.
>> The version og cURL that I have here is:
>> $ curl-config --version
>> libcurl 7.10.6
>> I can add a ticked for that, sure.
>> Continuing the build the process I am facing another error:
>> kml.h:41:2: #error "Old version of expat, please upgrade to expat 2.x"
>> I will try --without-kml ?
> Ivan,
> I think you will want to do "--without-expat"
> Best regards,
