[gdal-dev] gdalwarp trunk and FWtools giving different results
Joaquim Luis jluis at ualg.pt
Wed May 28 10:50:53 EDT 2008
I am very puzzled with this difference between the outputs of gdalwarp
form a couple of days old Trunk version versus FWtools 2.2.0
In both cases the command is the following
gdalwarp -s_srs "+proj=merc +R=6371008.7714" -t_srs EPSG:4326 alg.tiff
alg_geo.tiff
but the trunk version has
Upper Left  (  -8.0862815,  37.3460021) (  8d 5'10.61"W, 37d20'45.61"N)
Lower Left  (  -8.0862815,  37.0644230) (  8d 5'10.61"W, 37d 3'51.92"N)
Upper Right (  -7.7343076,  37.3460021) (  7d44'3.51"W, 37d20'45.61"N)
Lower Right (  -7.7343076,  37.0644230) (  7d44'3.51"W, 37d 3'51.92"N)
Center      (  -7.9102945,  37.2052125) (  7d54'37.06"W, 37d12'18.77"N)
whilst  FW
Upper Left  (  -8.0862815,  37.1605907) (  8d 5'10.61"W, 37d 9'38.13"N)
Lower Left  (  -8.0862815,  36.8792107) (  8d 5'10.61"W, 36d52'45.16"N)
Upper Right (  -7.7339340,  37.1605907) (  7d44'2.16"W, 37d 9'38.13"N)
Lower Right (  -7.7339340,  36.8792107) (  7d44'2.16"W, 36d52'45.16"N)
Center      (  -7.9101077,  37.0199007) (  7d54'36.39"W, 37d 1'11.64"N)
Note the differences in latitude.
The FW solution, as far as I can tell from plotting a coastline, is the
correct solution.
What can explain those differences.
NOTE, I do have GDAL_DATA pointing to the SVN data directory
Joaquim Luis
