[gdal-dev] gdalwarp trunk and FWtools giving different results
Joaquim Luis
jluis at ualg.pt
Wed May 28 14:56:33 EDT 2008
Testing with RC2 shows that the wrong result persists like with the
trunk version.
with a small variation now
gdalwarp -s_srs "+proj=merc +R=6371008.7714" -t_srs "+proj=latlong
+datum=WGS84" alg.tiff alg_geo.tiff
I have put the file at
ftp.ualg.pt/users/jluis/alg.tiff
Shell I file a ticket saying that gdalwarp is broken when converting
from Mercator?
Joaquim Luis
> Hi,
> I am very puzzled with this difference between the outputs of gdalwarp
> form a couple of days old Trunk version versus FWtools 2.2.0
> In both cases the command is the following
> gdalwarp -s_srs "+proj=merc +R=6371008.7714" -t_srs EPSG:4326 alg.tiff
> alg_geo.tiff
> but the trunk version has
> Upper Left ( -8.0862815, 37.3460021) ( 8d 5'10.61"W, 37d20'45.61"N)
> Lower Left ( -8.0862815, 37.0644230) ( 8d 5'10.61"W, 37d 3'51.92"N)
> Upper Right ( -7.7343076, 37.3460021) ( 7d44'3.51"W, 37d20'45.61"N)
> Lower Right ( -7.7343076, 37.0644230) ( 7d44'3.51"W, 37d 3'51.92"N)
> Center ( -7.9102945, 37.2052125) ( 7d54'37.06"W, 37d12'18.77"N)
> whilst FW
> Upper Left ( -8.0862815, 37.1605907) ( 8d 5'10.61"W, 37d 9'38.13"N)
> Lower Left ( -8.0862815, 36.8792107) ( 8d 5'10.61"W, 36d52'45.16"N)
> Upper Right ( -7.7339340, 37.1605907) ( 7d44'2.16"W, 37d 9'38.13"N)
> Lower Right ( -7.7339340, 36.8792107) ( 7d44'2.16"W, 36d52'45.16"N)
> Center ( -7.9101077, 37.0199007) ( 7d54'36.39"W, 37d 1'11.64"N)
> Note the differences in latitude.
> The FW solution, as far as I can tell from plotting a coastline, is
> the correct solution.
> What can explain those differences.
> NOTE, I do have GDAL_DATA pointing to the SVN data directory
> Joaquim Luis
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
