[gdal-dev] GDAL 1.6.0 GDALValidateCreationOptions
Peng Gao pgao at esri.com
Mon Nov 3 19:53:32 EST 2008
Hi Even,
I got the failure when converting a 3 band img to a BMP image. I think converting
a tiff to BMP will reproduce as well.
I was thinking to make validation optional at run time by setting, e.g.
config value.
Thanks,
Gao, Peng
> -----Original Message-----
> From: Even Rouault [mailto:even.rouault at mines-paris.org]
> Sent: Monday, November 03, 2008 2:43 PM
> To: gdal-dev at lists.osgeo.org
> Cc: Peng Gao
> Subject: Re: [gdal-dev] GDAL 1.6.0 GDALValidateCreationOptions
> Hi,
> Create()/CreateCopy() shouldn't fail if there's a warning due
> to GDALValidateCreationOptions(). At least, I don't
> understand how this can happen. Do you notice that behaviour
> with a specific driver ? I couldn't reproduce a failure.
> For example, something like:
> gdal_translate foo.tif bar.tif -co BAD_OPTION=YES
> just emits "Warning 6: Driver GTiff does not support
> BAD_OPTION creation option" but the translation is done correctly.
> As far as avoiding the warning itself, there's always the
> possibility of querying the GDAL_DMD_CREATIONOPTIONLIST
> metadata item on the driver and look for the "TFW" string in
> it to see if the option is supported or not.
> What would be your idea to make it optional ? At compilation
> time ? Run time ?
> Regards,
> Even
> Le Monday 03 November 2008 23:11:45 Peng Gao, vous avez écrit :
> > Hi All,
> > Create()/CreateCopy() now validates the creation options using
> GDALValidateCreationOptions() generates
> > a warning if any of creation options is not supported by the driver.
> > Create()/CreateCopy() fails if there is a warning.
> > This seems to be too harsh. My app breaks now since it
> always includes
> > a "TFW" creation option.
> > Can the validation be optional?
> > Regards,
> > Gao, Peng
> > gdal-dev mailing list
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
