[gdal-dev] GDAL 1.6.0 GDALValidateCreationOptions
Even Rouault
even.rouault at mines-paris.org
Tue Nov 4 16:17:03 EST 2008
Gao,
I've tried gdal_translate on a 3 band TIFF to a BMP image and it works. Well,
I get the warning twice because the BMP driver doesn't implement the
CreateCopy() method, but apart the warning, the resulting image is correct.
I'd be interested if you could find some code snippet that reproduces the
problem.
Anyway, I've added as you suggested a configuration option to skip the call to
GDALValidateCreationOptions(). Just define GDAL_VALIDATE_CREATION_OPTIONS=NO.
The default is YES, which I believe is the most sensible value for most
usages. I personnaly find it usefull to be reminded that I pass wrong options
due to typo, etc..
See http://trac.osgeo.org/gdal/changeset/15685
Regards,
Even
Le Tuesday 04 November 2008 01:53:32 Peng Gao, vous avez écrit :
> Hi Even,
> I got the failure when converting a 3 band img to a BMP image. I think
> converting a tiff to BMP will reproduce as well.
> I was thinking to make validation optional at run time by setting, e.g.
> config value.
> Thanks,
> Gao, Peng
> > -----Original Message-----
> > From: Even Rouault [mailto:even.rouault at mines-paris.org]
> > Sent: Monday, November 03, 2008 2:43 PM
> > To: gdal-dev at lists.osgeo.org
> > Cc: Peng Gao
> > Subject: Re: [gdal-dev] GDAL 1.6.0 GDALValidateCreationOptions
> > Hi,
> > Create()/CreateCopy() shouldn't fail if there's a warning due
> > to GDALValidateCreationOptions(). At least, I don't
> > understand how this can happen. Do you notice that behaviour
> > with a specific driver ? I couldn't reproduce a failure.
> > For example, something like:
> > gdal_translate foo.tif bar.tif -co BAD_OPTION=YES
> > just emits "Warning 6: Driver GTiff does not support
> > BAD_OPTION creation option" but the translation is done correctly.
> > As far as avoiding the warning itself, there's always the
> > possibility of querying the GDAL_DMD_CREATIONOPTIONLIST
> > metadata item on the driver and look for the "TFW" string in
> > it to see if the option is supported or not.
> > What would be your idea to make it optional ? At compilation
> > time ? Run time ?
> > Regards,
> > Even
> > Le Monday 03 November 2008 23:11:45 Peng Gao, vous avez écrit :
> > > Hi All,
> > > Create()/CreateCopy() now validates the creation options using
> > GDALValidateCreationOptions() generates
> > > a warning if any of creation options is not supported by the driver.
> > > Create()/CreateCopy() fails if there is a warning.
> > > This seems to be too harsh. My app breaks now since it
> > always includes
> > > a "TFW" creation option.
> > > Can the validation be optional?
> > > Regards,
> > > Gao, Peng
> > > _______________________________________________
> > > gdal-dev mailing list
> > > http://lists.osgeo.org/mailman/listinfo/gdal-dev
