[gdal-dev] OGR DeleteFeature throws memory exception
Brad Grinstead
bgrinstead at iavo-rs.com
Wed Nov 5 11:01:00 EST 2008
I am wondering if someone has experienced a memory access violation when attempting to delete OGRFeatures. I am running the latest build off the trunk and have been able to find no information regarding this error.
Basically, I am following the OGR API tutorial format, with a wrapper for the OGR functionality. The code looks like this:
for (int j = 0; j < featureCount; j++)
if ((feature = layer.GetNextFeature()) == null)
continue;
geometry = feature.GetGeometry();
if (geometry != null)
geoType = geometry.GetGeometryType();
//PROCESS GEOMETRY
feature.Dispose();
and the dispose function for the feature's wrapper is:
!Feature()
if (disposed)
return;
try
OGRFeature::DestroyFeature(this->feat);
catch (System::Exception^)
Console::WriteLine("AVE:Feature");
disposed = true;
On some shapefiles (not all) the DestroyFeature function throws an AccessViolationException. When run through the ingestion loop, a number of these are thrown before the application crashes. If I comment out the DestroyFeature call, the ingestion succeeds, but I think it is opening a hole for memory leaks. Sort of a "damned if you do, damned if you don't" situation.
Thanks in advance,
Brad G.
