[gdal-dev] DIMAP driver fail to get some meta data
Even Rouault even.rouault at mines-paris.org
Thu Nov 6 14:17:31 EST 2008
Guillaume,
yes, what you've observed is consistant with the source code of the driver.
To improve the situation, I've added in r15687 support for setting metadata at
the raster band level (that is to say with GDALRasterBand::GetMetadata)
Here's the new output :
$ apps/gdalinfo dimap/DN000340T_L1R.dim
Driver: DIMAP/SPOT DIMAP
Files: dimap/DN000340T_L1R.dim
       dimap/DN000340T_L1R.tif
Metadata:
  DATASET_PRODUCER_NAME=DMC International Imaging Ltd.
  DATASET_PRODUCTION_DATE=2006-06-08
  MISSION=NIGERIASAT
  IMAGING_DATE=2006-01-30
  IMAGING_TIME=09:18:22
  GEOMETRIC_PROCESSING=1R
  RADIOMETRIC_PROCESSING=Cubic convolution
  SPECTRAL_BAND_INDEX=1
  SPECTRAL_BAND_DESCRIPTION=NIR
  SPECTRAL_PHYSICAL_GAIN=0.6376299283778701
  SPECTRAL_PHYSICAL_BIAS=0.0642515909964508
  SPECTRAL_PHYSICAL_UNIT=W/m2/sr/m-6
Band 1 Block=6703x8 Type=Byte, ColorInterp=Red
  Metadata:
Band 2 Block=6703x8 Type=Byte, ColorInterp=Green
  Metadata:
    BAND_DESCRIPTION=RED
    PHYSICAL_GAIN=0.6190674084836884
    PHYSICAL_BIAS=0.0666344554873623
Band 3 Block=6703x8 Type=Byte, ColorInterp=Blue
  Metadata:
    BAND_DESCRIPTION=GREEN
    PHYSICAL_GAIN=0.717558361863802
    PHYSICAL_BIAS=0.019273652406175568
In case someone relied on the SPECTRAL_xxx metadata items in the dataset
metadata, I've kept them but they should be considered as a deprecated way of
getting the metadata at the raster band level.
Best regards,
Even
Le Wednesday 05 November 2008 16:39:42 guillaume huby, vous avez écrit :
> I have some trouble getting some meta data using DIMAP Driver.
> gdalinfo --version
> > GDAL 1.6.0dev, FWTools 2.2.8, released 2008/10/29
> Sample data can be found here :
> ftp://ftp.dmcii.com/samples/32m_MS_L1R/DN000340T_L1R.zip
> The meta data file contains this data :
> > <Image_Interpretation>
> >         <Spectral_Band_Info>
> >             <BAND_INDEX>1</BAND_INDEX>
> >             <BAND_DESCRIPTION>NIR</BAND_DESCRIPTION>
> >             <PHYSICAL_GAIN>0.6376299283778701</PHYSICAL_GAIN>
> >             <PHYSICAL_BIAS>0.0642515909964508</PHYSICAL_BIAS>
> >             <PHYSICAL_UNIT>W/m2/sr/m-6</PHYSICAL_UNIT>
> >         </Spectral_Band_Info>
> >             <BAND_INDEX>2</BAND_INDEX>
> >             <BAND_DESCRIPTION>RED</BAND_DESCRIPTION>
> >             <PHYSICAL_GAIN>0.6190674084836884</PHYSICAL_GAIN>
> >             <PHYSICAL_BIAS>0.0666344554873623</PHYSICAL_BIAS>
> >             <BAND_INDEX>3</BAND_INDEX>
> >             <BAND_DESCRIPTION>GREEN</BAND_DESCRIPTION>
> >             <PHYSICAL_GAIN>0.717558361863802</PHYSICAL_GAIN>
> >             <PHYSICAL_BIAS>0.019273652406175568</PHYSICAL_BIAS>
> >     </Image_Interpretation>
> And gdalinfo outputs :
> >gdalinfo DN000340T_L1R.dim
> > Metadata:
> The problem is that there is spectral info only for first band. I would
> like to see the data for each band.
> I also made a C++ program using the API ( GDALDataset::GetMetadata and
> GDALRasterBand::GetMetadata )giving no more results.
> Is there some turn-around to get the meta-data using the driver ?
> Should I submit a bug ?
> Thank you for your reply.
> Guillaume.
