[gdal-dev] Is GDAL reentrant
Clay, Bruce bclay at ball.com
Fri Nov 7 08:46:00 EST 2008
I have a Microsoft application with multiple tabs / property pages.
Each tab is controlled by a separate class.  I have a separate instance
of GDAL in each class.  I also had an instance in a popup that I used to
connect to the database.  After the user logins and the popup window
goes away it seems that I have to reregister the OGR drivers in the tabs
as if the OGRCleanupAll in the destructor of the popup was being applied
to the instances in the tabs as well.
Is GDAL / OGR reentrant?  Can we have multiple instances that act
independently?
Bruce
This message and any enclosures are intended only for the addressee.  Please
notify the sender by email if you are not the intended recipient.  If you are
not the intended recipient, you may not use, copy, disclose, or distribute this
message or its contents or enclosures to any other person and any such actions
may be unlawful.  Ball reserves the right to monitor and review all messages
and enclosures sent to or from this email address.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20081107/2fd03a21/attachment.html
