(nwl) Re: [gdal-dev] Saving data to the TEXT domain NITF
Kurt Landrus
klandrus at progeny.net
Fri Nov 7 07:46:28 EST 2008
What about TRE domain data, does the NITF driver support saving data
to the TRE domain?
I've tried the following code to save tre data, but there is not TRE
segment in the new file, and
the error code returned is 0.
err = GDALSetMetadataItem(dataset, tre, treValue, "TRE");
IFDBG printf( " saved TRE %s= %s\n errcode=%i\n", tre,
treValue, err);
Kurt Landrus
Progeny Systems Corp.
Office: 703-368-6107 x424
Lab: 703-368-6107 x520
On Oct 27, 2008, at 3:59 PM, Frank Warmerdam wrote:
> Kurt Landrus wrote:
>> Hello;
>> I working with GDAL to support NITF imagery, I'm having a problem
>> with trying to save text data to the I can read data from the Text
>> segment just fine. However when I try to save data back to the nitf
>> in the TEXT segment using the call
>> below, I receive no err, but the data doesn't get saved.
>> // save text segment to dataset.
>> err = GDALSetMetadataItem(dataset, "DATA_0", tmp3, "TEXT");
>> When I try to verify the text in the TEXT segment using gdalinfo,
>> there is no TEXT segment data contained in the NITF file.
>> Is there other calls required to set up this, what I am doing wrong.
>> Thanks;
> Kurt,
> I believe that at this time the GDAL NITF driver does not support
> writing
> out text segments.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for
> Rent
