[gdal-dev] gdal_rasterize usage problems
Markus Neteler neteler at osgeo.org
Tue Nov 11 05:08:57 EST 2008
On Mon, Nov 10, 2008 at 10:43 PM, Roger André <randre at gmail.com> wrote:
> Andrew,
> I believe your syntax is incorrect.  Assuming that you are trying to exclude
> water from your image, it should be something like this:
> % gdal_rasterize -b 1 -b 2 -b 3 -i -burn 0 -burn 0 -burn 0 -l gshhs_land
> gshhs_land.shp warped.tif
> Have a look at http://www.gdal.org/gdal_rasterize.html for a list of all the
> options.
Roger,
it fails also for me (using recent trunk).
Markus
