[gdal-dev] gdal_rasterize usage problems
Roger André randre at gmail.com
Tue Nov 11 12:43:13 EST 2008
Hi Markus,
A friend of mine just tried this out on r15709 and reports that it works
fine.  Are you referring to the syntax in the original email not working, or
what I advised Andrew to try?  If it's the latter, please send the command
you're using, so we can dissect it.
Thanks,
Roger
On Tue, Nov 11, 2008 at 2:08 AM, Markus Neteler <neteler at osgeo.org> wrote:
> On Mon, Nov 10, 2008 at 10:43 PM, Roger André <randre at gmail.com> wrote:
> > Andrew,
> > I believe your syntax is incorrect.  Assuming that you are trying to
> exclude
> > water from your image, it should be something like this:
> > % gdal_rasterize -b 1 -b 2 -b 3 -i -burn 0 -burn 0 -burn 0 -l gshhs_land
> > gshhs_land.shp warped.tif
> > Have a look at http://www.gdal.org/gdal_rasterize.html for a list of all
> the
> > options.
> Roger,
> it fails also for me (using recent trunk).
> Markus
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20081111/39bd69ce/attachment.html
