[gdal-dev] The use of geometry_columns of the Pg driver
Ari Jolma ari.jolma at tkk.fi
Wed Nov 12 04:26:13 EST 2008
The Pg driver consults geometry_columns for the list of layers in the
database and for the geometry type of a layer. But it does not consult
it for the geometry column itself. For example:
I have a table "points", which is created with shp2psql and it is fine
with OGR. Then I decide to add another geometry column, which will
contain the points transformed somehow. I can now either add this as a
new entry in the geometry_columns table or edit the existing entry to
have the new column name. In either scenario OGR is by default a bit
lost. I need to use SQL to get an OGR layer of the points with the new,
alternative coordinates.
Should this disregard of column names in geometry_columns be considered
a bug or feature?
Best regards,
Ari
