[gdal-dev] The use of geometry_columns of the Pg driver
Ari Jolma
ari.jolma at tkk.fi
Wed Nov 12 04:38:28 EST 2008
Open ticket 1476 seems to be discussing this issue.
http://trac.osgeo.org/gdal/ticket/1476
Ari
Ari Jolma wrote:
> The Pg driver consults geometry_columns for the list of layers in the
> database and for the geometry type of a layer. But it does not consult
> it for the geometry column itself. For example:
> I have a table "points", which is created with shp2psql and it is fine
> with OGR. Then I decide to add another geometry column, which will
> contain the points transformed somehow. I can now either add this as a
> new entry in the geometry_columns table or edit the existing entry to
> have the new column name. In either scenario OGR is by default a bit
> lost. I need to use SQL to get an OGR layer of the points with the
> new, alternative coordinates.
> Should this disregard of column names in geometry_columns be
> considered a bug or feature?
> Best regards,
> Ari
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
