[gdal-dev] The use of geometry_columns of the Pg driver
Even Rouault even.rouault at mines-paris.org
Wed Nov 12 13:19:37 EST 2008
For those interested, I've commited code based on Ari's patch to support
tables with multiple geometry columns. See ticket 1476 and/or updated PG
driver documentation for the details
Le Wednesday 12 November 2008 10:38:28 Ari Jolma, vous avez écrit :
> Open ticket 1476 seems to be discussing this issue.
> http://trac.osgeo.org/gdal/ticket/1476
> Ari
> Ari Jolma wrote:
> > The Pg driver consults geometry_columns for the list of layers in the
> > database and for the geometry type of a layer. But it does not consult
> > it for the geometry column itself. For example:
> > I have a table "points", which is created with shp2psql and it is fine
> > with OGR. Then I decide to add another geometry column, which will
> > contain the points transformed somehow. I can now either add this as a
> > new entry in the geometry_columns table or edit the existing entry to
> > have the new column name. In either scenario OGR is by default a bit
> > lost. I need to use SQL to get an OGR layer of the points with the
> > new, alternative coordinates.
> > Should this disregard of column names in geometry_columns be
> > considered a bug or feature?
> > Best regards,
> > Ari
> > gdal-dev mailing list
> > gdal-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
