[gdal-dev] Problem with gdal-1.5.3 and FreeBSD 6.2
Matej
matej at matnet.net
Wed Nov 12 08:49:58 EST 2008
I have a problem with getting gdal to compile on FreeBSD 6.2. My problem is exactly the same as the one described here http://lists.osgeo.org/pipermail/gdal-dev/2007-November/014763.html.
I run configure with:./configure --with-pg=/usr/local/pgsql/bin/pg_config
My configure ouput is
GDAL is now configured for i386-unknown-freebsd6.2
Installation directory: /usr/local
C compiler: gcc -g -O2
C++ compiler: g++ -g -O2
LIBTOOL support: yes
LIBZ support: external
GRASS support: no
CFITSIO support: no
PCRaster support: internal
NetCDF support: no
LIBPNG support: internal
LIBTIFF support: internal (BigTIFF=yes)
LIBGEOTIFF support: internal
LIBJPEG support: internal
LIBGIF support: internal
OGDI support: no
HDF4 support: no
HDF5 support: no
Kakadu support: no
JasPer support: no
ECW support: no
MrSID support: no
GRIB support: no
cURL support (wms/wcs/...):yes
PostgreSQL support: no
MySQL support: no
Xerces-C support: no
Expat support: yes
ODBC support: no
PGeo support: no
OCI support: no
SDE support: no
DODS support: no
SQLite support: no
DWGdirect support no
PANORAMA GIS support: no
INFORMIX DataBlade support:no
GEOS support: yes
Old-gen python no
SWIG Bindings: no
Statically link PROJ.4: no
enable OGR building: yes
enable pthread support: no
hide internal symbols: no
When building I get a couple of :not found errors, which look like these:
/bin/sh /home/matej/mapserver/gdal-1.5.3/libtool --mode=link g++ gdalinfo.o \
/home/matej/mapserver/gdal-1.5.3/libgdal.la -o gdalinfo
libtool_args+=: not found
compile_command+=: not found
finalize_command+=: not found
libtool: link: g++ /home/matej/mapserver/gdal-1.5.3/.libs/libgdal.so -L/usr/local/lib /usr/local/lib/libgeos_c.so /usr/local/lib/libgeos.so /usr/local/lib/libexpat.so /usr/local/lib/libcurl.so -lssl -lcrypto -lz -Wl,-rpath -Wl,/usr/local/lib
/usr/lib/crt1.o(.text+0x72): In function `_start':
: undefined reference to `main'
gmake[1]: *** [gdalinfo] Error 1
I can't find any useful idea, I need libtool but I was able to get it to work long time ago on a FreeBSD 6.2 machine.
I had libtool 1.5 installed and now have 2.2.6, but the error is the same.
I would be very glad for any help whatsoever,
thank you in advance, Matej Serc
matej at matnet.net
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20081112/acc338a2/attachment.html
