[gdal-dev] Problem with gdal-1.5.3 and FreeBSD 6.2
Matej matej at matnet.net
Wed Nov 12 19:38:20 EST 2008
Hello,
I have just realized that there is a problem with shell - I don't know why /bin/sh is used instead of /bin/bash:
gmake[1]: Entering directory `/usr/home/matej/mapserver/gdal-1.5.3/apps'
/bin/sh /home/matej/mapserver/gdal-1.5.3/libtool --mode=link    g++  gdalinfo.o  \
                /home/matej/mapserver/gdal-1.5.3/libgdal.la -o gdalinfo
libtool_args+=: not found
compile_command+=: not found
finalize_command+=: not found
If I run it with /bin/bash, it works. Now where can I set the default shell used in this and other cases?
Thanks, Matej
matej at matnet.net
  ----- Original Message -----
  To: gdal-dev at lists.osgeo.org
  Sent: Wednesday, November 12, 2008 2:49 PM
  Subject: [gdal-dev] Problem with gdal-1.5.3 and FreeBSD 6.2
  I have a problem with getting gdal to compile on FreeBSD 6.2. My problem is exactly the same as the one described here http://lists.osgeo.org/pipermail/gdal-dev/2007-November/014763.html.
  I run configure with:./configure --with-pg=/usr/local/pgsql/bin/pg_config
  My configure ouput is
  GDAL is now configured for i386-unknown-freebsd6.2
    Installation directory:    /usr/local
    C compiler:                gcc -g -O2
    C++ compiler:              g++ -g -O2
    LIBTOOL support:           yes
    LIBZ support:              external
    GRASS support:             no
    CFITSIO support:           no
    PCRaster support:          internal
    NetCDF support:            no
    LIBPNG support:            internal
    LIBTIFF support:           internal (BigTIFF=yes)
    LIBGEOTIFF support:        internal
    LIBJPEG support:           internal
    LIBGIF support:            internal
    OGDI support:              no
    HDF4 support:              no
    HDF5 support:              no
    Kakadu support:            no
    JasPer support:            no
    ECW support:               no
    MrSID support:             no
    GRIB support:              no
    cURL support (wms/wcs/...):yes
    PostgreSQL support:        no
    MySQL support:             no
    Xerces-C support:            no
    Expat support:             yes
    ODBC support:              no
    PGeo support:              no
    OCI support:               no
    SDE support:               no
    DODS support:              no
    SQLite support:            no
    DWGdirect support          no
    PANORAMA GIS support:      no
    INFORMIX DataBlade support:no
    GEOS support:              yes
    Old-gen python          no
    SWIG Bindings:          no
    Statically link PROJ.4:    no
    enable OGR building:       yes
    enable pthread support:    no
    hide internal symbols:     no
  When building I get a couple of :not found errors, which look like these:
  libtool: link: g++  /home/matej/mapserver/gdal-1.5.3/.libs/libgdal.so -L/usr/local/lib /usr/local/lib/libgeos_c.so /usr/local/lib/libgeos.so /usr/local/lib/libexpat.so /usr/local/lib/libcurl.so -lssl -lcrypto -lz -Wl,-rpath -Wl,/usr/local/lib
  /usr/lib/crt1.o(.text+0x72): In function `_start':
  : undefined reference to `main'
  gmake[1]: *** [gdalinfo] Error 1
  I can't find any useful idea, I need libtool but I was able to get it to work long time ago on a FreeBSD 6.2 machine.
  I had libtool 1.5 installed and now have 2.2.6, but the error is the same.
  I would be very glad for any help whatsoever,
  thank you in advance, Matej Serc
  matej at matnet.net
  gdal-dev mailing list
  http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20081113/f8d2fba2/attachment-0001.html
