[gdal-dev] gdal_rasterize usage problems
Wed Nov 12 09:06:01 EST 2008
Andrew Brooks wrote:
> On Mon, 10 Nov 2008 21:43:02 -0000, Roger André <randre at gmail.com> wrote:
>> I believe your syntax is incorrect.
> The manual implies that the -b and -burn options are optional but they appear
> to be mandatory.
Andrew,
One of -3d, -burn or -a are required.   I have not found anything in the
manual that seems to imply they are optional.
> Giving just a source and destination results in the usage
> message.  The only option noted as mandatory is -l but if only -l is used then
> the misspelled and confusing message is "To many of -3d, -burn and -a specified".
I have corrected the message to indicate that one of these is required.
Best regards,
