[gdal-dev] GDAL and numpy, masking arrays
Armin Burger
armin.burger at gmx.net
Wed Nov 12 15:54:50 EST 2008
Chris
thanks a lot for the quick and very helpful explanations. Is there a
possibility to reset the masked values '--' after the calculation to a
special value?
Best regards
Armin
On 12/11/2008 21:27, Christopher Barker wrote:
> Armin Burger wrote:
>> maybe someone on this list has some experience using numpy in
>> combination with GDAL/Python and could give me some advice.
> For further questions about numpy, the numpy list is very helpful.
>> difference can be easily calculated after reading both images into an
>> array and substract one from the other.
>> The problem is that both images can contain clouds or snow that have
>> predefined pixel values (252,253).
>> Does anybody know if this is possible and how to perform it?
> yep.
>> Looking through the numpy docs I was not able to identify required
>> methods or functions for this. There is something like 'masked arrays'
>> but I have not understood if this could be used for my purpose.
> This is exactly the kind of thing masked arrays are for. Yu can create a
> masked array out of your data with something like:
> >>> a
> array([ 1, 2, 3, 4, 5, 6, 3, 4, 67, 4, 3, 5, 6, 7])
> #a regular array
> >>> import numpy.ma as ma
> # create a masked array with the mask set at all elements with a value
> of 3:
> >>> a = ma.masked_values(a, 3)
> >>> a
> masked_array(data = [1 2 -- 4 5 6 -- 4 67 4 -- 5 6 7],
> mask = [False False True False False False True False False
> False True False
> False False],
> fill_value=3)
> #another one:
> >>> b = np.array((1,3,4,2,4,7,4,5,23,5,7,3,8,5))
> >>> b = ma.masked_values(b, 3)
> >>> b
> masked_array(data = [1 -- 4 2 4 7 4 5 23 5 7 -- 8 5],
> mask = [False True False False False False False False False
> False False True
> False False],
> fill_value=3)
> add them together:
> >>> c = a+b
> >>> c
> masked_array(data = [2 -- -- 6 9 13 -- 9 90 9 -- -- 14 12],
> mask = [False True True False False False True False False
> False True True
> False False],
> fill_value=3)
> If your values are Floating Point, then Another option would be to
> replace all the "cloud" values with NaN:
> >>> a = np.array((1,2,3,4,5,6,3,4,67,4,3,5,6,7), dtype=np.float)
> >>> a[a==3] = np.nan
> >>> a
> array([ 1., 2., NaN, 4., 5., 6., NaN, 4., 67., 4., NaN,
> 5., 6., 7.])
> >>> b = np.array((1,3,4,2,4,7,4,5,23,5,7,3,8,5), dtype=np.float)
> >>> b[b==3] = np.nan
> >>> b
> array([ 1., NaN, 4., 2., 4., 7., 4., 5., 23., 5., 7.,
> NaN, 8., 5.])
> >>> a+b
> array([ 2., NaN, NaN, 6., 9., 13., NaN, 9., 90., 9., NaN,
> NaN, 14., 12.])
> -Chris
