[gdal-dev] GDAL and numpy, masking arrays
Armin Burger
armin.burger at gmx.net
Wed Nov 12 16:50:45 EST 2008
I guess I found it, looks like the function
filled(c, 255)
does this.
Armin
On 12/11/2008 21:54, Armin Burger wrote:
> Chris
> thanks a lot for the quick and very helpful explanations. Is there a
> possibility to reset the masked values '--' after the calculation to a
> special value?
> Best regards
> Armin
> On 12/11/2008 21:27, Christopher Barker wrote:
>> Armin Burger wrote:
>>> maybe someone on this list has some experience using numpy in
>>> combination with GDAL/Python and could give me some advice.
>> For further questions about numpy, the numpy list is very helpful.
>>> difference can be easily calculated after reading both images into an
>>> array and substract one from the other.
>>> The problem is that both images can contain clouds or snow that have
>>> predefined pixel values (252,253).
>>> Does anybody know if this is possible and how to perform it?
>> yep.
>>> Looking through the numpy docs I was not able to identify required
>>> methods or functions for this. There is something like 'masked
>>> arrays' but I have not understood if this could be used for my purpose.
>> This is exactly the kind of thing masked arrays are for. Yu can create
>> a masked array out of your data with something like:
>> >>> a
>> array([ 1, 2, 3, 4, 5, 6, 3, 4, 67, 4, 3, 5, 6, 7])
>> #a regular array
>> >>> import numpy.ma as ma
>> # create a masked array with the mask set at all elements with a value
>> of 3:
>> >>> a = ma.masked_values(a, 3)
>> >>> a
>> masked_array(data = [1 2 -- 4 5 6 -- 4 67 4 -- 5 6 7],
>> mask = [False False True False False False True False False
>> False True False
>> False False],
>> fill_value=3)
>> #another one:
>> >>> b = np.array((1,3,4,2,4,7,4,5,23,5,7,3,8,5))
>> >>> b = ma.masked_values(b, 3)
>> >>> b
>> masked_array(data = [1 -- 4 2 4 7 4 5 23 5 7 -- 8 5],
>> mask = [False True False False False False False False False
>> False False True
>> False False],
>> fill_value=3)
>> add them together:
>> >>> c = a+b
>> >>> c
>> masked_array(data = [2 -- -- 6 9 13 -- 9 90 9 -- -- 14 12],
>> mask = [False True True False False False True False False
>> False True True
>> False False],
>> fill_value=3)
>> If your values are Floating Point, then Another option would be to
>> replace all the "cloud" values with NaN:
>> >>> a = np.array((1,2,3,4,5,6,3,4,67,4,3,5,6,7), dtype=np.float)
>> >>> a[a==3] = np.nan
>> >>> a
>> array([ 1., 2., NaN, 4., 5., 6., NaN, 4., 67., 4., NaN,
>> 5., 6., 7.])
>> >>> b = np.array((1,3,4,2,4,7,4,5,23,5,7,3,8,5), dtype=np.float)
>> >>> b[b==3] = np.nan
>> >>> b
>> array([ 1., NaN, 4., 2., 4., 7., 4., 5., 23., 5., 7.,
>> NaN, 8., 5.])
>> >>> a+b
>> array([ 2., NaN, NaN, 6., 9., 13., NaN, 9., 90., 9., NaN,
>> NaN, 14., 12.])
>> -Chris
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
