Gdal Bug? was: Re: [gdal-dev] JP2MRSID Issues
Michael P. Gerlek
mpg at lizardtech.com
Thu Nov 13 11:50:16 EST 2008
Stephen, Frank:
Yes, this is indeed a Kakadu error coming from underneath our SDK. The
error "feels" like the sort of thing that happens when one is requesting
a bounding box that is outside of the legal bounds for the image at that
magnification level: that is, perhaps the scene parameters being
requested by GDAL, or as they are interpreted by the MrSID SDK, are
causing Kakadu to choke.
If you can figure out what the scene parameters being passed into the
MrSID SDK are, we could then call the SDK directly using the mrsiddecode
command line tool and see what happens.
-mpg & the gang
